Con Rod holding tool
Postby Andy B.L.C. » Sun Mar 28, 2021 9:12 pm
Evenin' y'all
Does anyone out there know where I could source a (not the flat plate that anyone could knock up in 5 mins) conrod holding tool...?
With many thanks!
Andy B.L.C.
Re: Con Rod holding tool
Postby Tractorman » Mon Mar 29, 2021 8:46 am
What does the one you want look like, Andy and what's wrong with the flat plate type?
Postby ULC Soulagent » Mon Mar 29, 2021 2:10 pm
Rimini have the original style type ;) tad pricey though :o
https://www.riminilambrettacentre.com/e ... otore.html
Postby hullygully » Mon Mar 29, 2021 5:47 pm
think I got mine from Scooter Restos
Postby Andy B.L.C. » Mon Mar 29, 2021 9:19 pm
Tractorman wrote:What does the one you want look like, Andy and what's wrong with the flat plate type?
I'm after the 'posh' one, sadly out of stock in most of the go to places - https://images.app.goo.gl/wyfHDxiVEiE6PS3w8
Having read Dicks book, being in possession of the blue & white 'bretta manual & saving a small fortune due to what were going through (at the expense of the Elmers Arms, best pub in Bristol 8-) ) I'm able to finally fill the gaps in my toolkit.
Absolutely nowt wrong with the flat type (apart from the price, for nothing), will knock one up at work & NOT! (dunno how I got away with it this long...) twist the crank :o
Andy B.L.C.
Postby Andy B.L.C. » Mon Mar 29, 2021 9:21 pm
ULC Soulagent wrote:Rimini have the original style type ;) tad pricey though :o
Cheerz Shane, nice1!
I've ordered 2 just in case I mislay one... :lol:
Andy B.L.C.
Postby Andy B.L.C. » Mon Mar 29, 2021 9:22 pm
hullygully wrote:think I got mine from Scooter Restos
Yup, bang on thank you, sadly sold out... :roll:
Andy B.L.C.
Postby nickw » Wed Mar 31, 2021 10:20 am
Not sure on tax/import duties but Jockeys say they have one?
https://www.jockeys-boxenstop.de/Conrod ... all-models
nickw
Postby Toddy » Wed Mar 31, 2021 5:00 pm
Think Warren has them at shaw-fire maybe worth a call
http://shaw-firelambrettaspares.co.uk/
Postby Andy B.L.C. » Thu Apr 01, 2021 9:14 pm
nickw wrote:Not sure on tax/import duties but Jockeys say they have one?
Good shout Nick & thanks(!), I expanded my search Tues evening & found likewise, the last one they had in stock... :D Time to take post brexit on the chin then...
Andy B.L.C.
Postby Andy B.L.C. » Thu Apr 01, 2021 9:23 pm
Toddy wrote:Think Warren has them at shaw-fire maybe worth a call
Ta loads Toddy (!) but I'd already phoned the motherland & ordered...
Andy B.L.C.
Postby Knowledge » Fri Apr 02, 2021 8:41 pm
I have seen photos of this tool before, but I just can’t work out how it is used.
Presumably it is a con-rod holding tool rather than a crank holding tool.
Perhaps I lack imagination, but it has me stumped.
(I sit back and prepare myself for a “Doh! It really is THAT obvious” moment)
Postby Tractorman » Sat Apr 03, 2021 9:05 am
I asked the question why is it better than the flat plate version but received no response. Looking at them, the alternative tool, the conrod goes through the hole and locks as the crank turns. This does not stress the big end bearing. I maybe completely wrong as usual!
Postby Warkton Tornado No.1 » Sat Apr 03, 2021 4:19 pm
Tractorman wrote:I asked the question why is it better than the flat plate version but received no response. Looking at them, the alternative tool, the conrod goes through the hole and locks as the crank turns. This does not stress the big end bearing. I maybe completely wrong as usual!
I've used my slotted plate type on a lot of engine builds & the only advantage I can see to spending more than the fiver mine cost is that the pan handle type won't ring like a tuning fork if you put it down carelessly...... ;)
There must be a lot of money about despite the economy....
Postby Knowledge » Sat Apr 03, 2021 9:13 pm
I stick the handle of a small screwdriver in the slot between the two webs. As the big-end comes around, the handle stops the crank rotating. It puts no stress on the big-end bearing.
I have the slotted tool described elsewhere, but prefer my trusty screwdriver.
Postby hullygully » Fri Apr 09, 2021 4:03 pm
the 'pan handle' holder works a treat on SX or GP cranks as the con-rod locks onto the holder, but you struggle with a full circle crank
Postby coaster » Fri Apr 09, 2021 10:43 pm
Knowledge wrote:I stick the handle of a small screwdriver in the slot between the two webs. As the big-end comes around, the handle stops the crank rotating. It puts no stress on the big-end bearing.
Same here Martin and if the piston is in place I've used the plastic coated handles of a pair of pliers under the skirt.....probably not best practice though :?
