by al pushpak » Sat Mar 27, 2021 7:53 pm
Hi, been messing about the best part of the day with it trying to find tune the speed setting using a gps sat nav, it seems fine up to 40mph with regards to the gps , but once I reach about 50/60mph on the gps the speedo is 10 mph slower! ( at 50mph gps the speedo reads 40mph & at 60mph gps the speedo reads 50mph) I've messed about with the tyre circumference settings which I measured at 1300 mm & was the setting I started with but it makes no difference if I lower or higher this setting! the gear ratio is set 0.77 & the rpm setting is 3 & it runs a standard speedo cable not a magnetic pick up. any help much appreciated! that's in advance. Cheers
al pushpak
by bennn » Sun Mar 28, 2021 2:06 pm
Think you need the gear ratio at 1 for Lambretta, I beleive (may be wrong here) you only mess about with that on Vespas.
Ben.
bennn
by Fast n Furious » Mon Mar 29, 2021 12:20 am
TBH. it sounds like you have a problem with the speedo drive or cable for it to be giving you readings like this. ?????/
