by ianmoran » Wed Mar 17, 2021 11:40 pm
Asking for a mate,
He's built the engine up with a 2205 bearing instead of a 205. I don't know why.
The question is, will this still run ok with the dished washer in place or does he need to start again?
ianmoran
by Littlewheels » Thu Mar 18, 2021 12:01 am
Has he fitted a GP 200 crank? I think the 2205 bearing was fitted to GP 200's only from '69. All other engines use the 205.
Littlewheels
by ianmoran » Thu Mar 18, 2021 8:18 am
Yes, it's a GP crank
ianmoran
by davej » Thu Mar 18, 2021 8:20 am
The 2205 bearing will be fine you need to leave the spacing ring out
davej
by ianmoran » Thu Mar 18, 2021 9:45 pm
Sorry if this sounds daft but what happens if he leaves the dished washer in place?
ianmoran
by Fast n Furious » Thu Mar 18, 2021 11:37 pm
if the 3mm spacer washer fitted with a 2205 bearing then there is insufficient room left for the large oil seal and circlip!!!
