Spanish turning front mudguard
Postby al pushpak » Sat Jan 30, 2021 11:51 am
Hi,Just toying with the idea of fitting a Spanish turning front mudguard to my series 1, question is can it be fitted without the need to weld brackets to the fork legs? (I'm thinking of fabricating some kind of bracket for it to bolt to at the sides)the reasons being one, I can't weld & two, I would have to travel somewhere to get it all welded up which at the moment is obviously is a no no! also will it fit onto the top of series 1 italian forks? I have done some searches on this but can't really find much information. thanks in advance. cheers ;)
al pushpak
Re: Spanish turning front mudguard
Postby gaz_powell » Sat Jan 30, 2021 12:45 pm
The mudguard is not just held by the fork leg brackets.
The mudguard slips over a ring on the forks and is then clamped.
When I did it I turned the ring in steel and tapped the sides so I could use a grub screws instead of a clamp as I was using a fibreglass mudguard. Was consuerned a clamp would crack it as the mould wasn't great at that point.
The ring in the forks gives it some substance
I welded the brackets on the fork legs.
I'm sure there will a way to fab some sort of bolt on bracket, could you try something with the clamp on damper brackets with some butchery.
viewtopic.php?f=19&t=86&hilit=S2+bitsa+build&start=20
Postby al pushpak » Sat Jan 30, 2021 1:02 pm
Hi Gaz thanks for your reply & the link, definitely food for thought there. ;) cheers
al pushpak
Postby gaz_powell » Sat Jan 30, 2021 1:08 pm
When I set about it, I didn't know about the ring, I was expecting to just weld the fork leg brackets on.
Good luck
Postby al pushpak » Tue Feb 02, 2021 8:49 am
Hi Gaz, could you possibly tell me what size/dimensions the mudguard brackets on the side of the fork legs are please ? cheers ;)
al pushpak
Postby al pushpak » Tue Feb 02, 2021 1:03 pm
Sorted now ta ! ;)
al pushpak
Postby bike grim » Tue Feb 02, 2021 7:34 pm
If you got damper brackets on the forks already you could use them with longer bolts to save welding new brackets on. Won’t line up with the original holes in the mudguard but that doesn’t really matter. The ring around the top of forks is important. Also if there is a dust cover fitted above the bottom steering bearing race on your frame you’ll have to remove otherwise the ring will not fit
Postby gaz_powell » Wed Feb 03, 2021 11:41 am
Good point about the dustcover I'd forgot about that
Postby gaz_powell » Wed Feb 03, 2021 8:04 pm
Just saw that Buzz Solomoto sells the fork bracket and a ring and clamp kit.... Wish they'd been around when I did mine.
Postby gaz_powell » Sun Mar 07, 2021 9:03 am
How did you get on?
Postby al pushpak » Sun Mar 07, 2021 6:23 pm
Hi Gaz, yes, i got hold of a remade mudguard in fairly good condition,I wasn't too fussed about it being perfect as it's been to a Series 1 rat scoot, got a couple of the fork leg mudguard brackets from KS customs, apart from a bit of adjustment to stop it fouling the bottom of the horncast it was a fairly straightforward job ;) thanks again for all your help & advice,much appreciated . Cheers ;)
al pushpak
Postby gaz_powell » Mon Mar 08, 2021 8:59 pm
Good to hear, do you know you can buy bolt on horncover cheeks, to fill the gap below. If you check my thread they are on there somewhere, I think they from Keith Newman
Postby Toddy » Wed Mar 10, 2021 2:54 pm
gaz_powell wrote:Good to hear, do you know you can buy bolt on horncover cheeks, to fill the gap below. If you check my thread they are on there somewhere, I think they from Keith Newman
They are Gaz keith does them :D
Postby Toddy » Wed Mar 10, 2021 2:56 pm
