Disc brake joining nut
Postby Bobblybob » Wed Jan 27, 2021 1:26 am
Hi all
How tight do I do up the half nut that is put on the shaft that in effect holds the two halves of the disc brake together? Tighten then slacken off or what? Thanks
Bobblybob
Re: Disc brake joining nut
Postby dickie » Wed Jan 27, 2021 12:07 pm
I've just built 2 and simply tightened them up. I'm not sure why you'd need to slacken off. Is the hub locking up or something?
also, worth looking at this https://restoringlambrettas.blogspot.com/
Postby Bobblybob » Wed Jan 27, 2021 12:47 pm
Thanks. Just nervous about over tightening as it seems to bind if I tighten right up
Bobblybob
Postby dickie » Wed Jan 27, 2021 2:13 pm
Bobblybob wrote:Thanks. Just nervous about over tightening as it seems to bind if I tighten right up
it shouldn't bind up. Probably a good idea to strip and rebuild and follow the rebuild guide from Paul Slack.
I'm just guessing here, but if it's binding up, maybe you've missed a spacer out?
Postby Bobblybob » Wed Jan 27, 2021 6:12 pm
Looking at what you recommend I may have not put the inner bearing in far enough. Will strip again and have a look.
Bobblybob
Postby Warkton Tornado No.1 » Wed Jan 27, 2021 7:31 pm
As dickie suggested, the spacer tube is essential as that ensures just the correct amount of axial clearance remains in the deep groove ball bearings with no pre-loading.
If either bearing was not fully seated, then if you're sure of the rest of the build :? you could continue tightening to pull either fully home.......
I'm guessing, but best strip down again, eh? :lol:
Postby Bobblybob » Thu Jan 28, 2021 11:19 pm
Partially Stripped it down again this evening. Inner bearing wasn’t fully seated in. Couple of taps with a no.3 persuader , refitted oil seal and good as gold. Thanks. 8-)
Bobblybob
Users browsing this forum: No registered users and 92 guests
