Backfire
Backfire
Postby rodney » Sun Nov 15, 2020 9:06 pm
Hi, just rebuilt a li150 series 2. Got the 12v kit working correctly now and all I get is a backfire now and again when kicking over. It won’t fire up, any suggestions? Thanks
rodney
Re: Backfire
Postby MickYork » Sun Nov 15, 2020 9:17 pm
woodruff key sheared....maybe ?
Re: Backfire
Postby rodney » Sun Nov 15, 2020 9:29 pm
Should be fine as all new
rodney
Re: Backfire
Postby MK Monty » Sun Nov 15, 2020 10:58 pm
Very easy to shear it even a new one. Has it run OK and just started to backfire. I have sheared mine by not doing the flywheel up tight while strobing it up. It’s a clear sign the timing is out.next you look at stator pick up and does it line up with the flywheel. Lots of combinations of parts being supplied these days.
MK Monty
Re: Backfire
Postby drivera » Mon Nov 16, 2020 11:19 am
MickYork wrote:woodruff key sheared....maybe ?
+1 , done it a few times by not tightening up the flywheel nut properly
drivera
Re: Backfire
Postby rodney » Mon Nov 16, 2020 2:36 pm
MK Monty wrote:Very easy to shear it even a new one. Has it run OK and just started to backfire. I have sheared mine by not doing the flywheel up tight while strobing it up. It’s a clear sign the timing is out.next you look at stator pick up and does it line up with the flywheel. Lots of combinations of parts being supplied these days.
This is the first time to try and fire up after full rebuild
rodney
Re: Backfire
Postby missing lynx » Mon Nov 16, 2020 8:02 pm
I would double check your timing marks and re-strobe
Re: Backfire
Postby dscscotty » Tue Nov 17, 2020 9:52 pm
What type/make ignition system?
Re: Backfire
Postby coaster » Thu Nov 19, 2020 12:27 am
What does the compression feel like and is it a sharp backfire or more like a wet fart. Low compression can result in a wet bacfire as the gasses escape past the rings
Re: Backfire
Postby coaster » Thu Nov 19, 2020 12:30 am
coaster wrote:What does the compression feel like and is it a sharp backfire or more like a wet fart. Low compression can result in a wet bacfire as the gasses escape past the rings
Given the new rebuild though, the woodruff key as already mentioned would be the prime suspect as it is itting thre very easy to dislodge it when fitting the flywheel. been there etc :?
Re: Backfire
Postby Toddy » Thu Nov 19, 2020 7:10 am
Head Gasket / Seal ??
Re: Backfire
Postby ROClarke » Sun Nov 29, 2020 6:11 pm
Toddy wrote:Head Gasket / Seal ??
Yes I would suggest checking this as well,purely because I had similar symptoms on my TS1 a few years ago and after wasting loads of time and effort on carb and electrics it turned out to be head gasket
ROClarke
Re: Backfire
Postby solostax » Mon Nov 30, 2020 12:15 am
rodney wrote:Hi, just rebuilt a li150 series 2. Got the 12v kit working correctly now and all I get is a backfire now and again when kicking over. It won’t fire up, any suggestions? Thanks
Had almost identical problem that baffled me.Despite being doubtful of the majority of advisers pointing to the Woodfruff key being the cause. I nevertheless followed the
strong opinion and indeed found the new woodruff key had sheared and upset the timing.On replacing the part I also followed advice to lap the flywheel to the shaft. This welcome advice saved countless hours for which I'm still grateful.
Please advise any problems found when up and running.
Regards.
solostax
Re: Backfire
Postby rodney » Sat Dec 12, 2020 6:30 pm
Backfire has gone, checked woodruff key and reset timing now I get nothing at all. Got spark and fuel but she just won’t fire up. Thanks for everyone’s help
rodney
Re: Backfire
Postby aby » Mon Jan 11, 2021 11:04 pm
rodney wrote:Backfire has gone, checked woodruff key and reset timing now I get nothing at all. Got spark and fuel but she just won’t fire up. Thanks for everyone’s help
Any joy yet, interested to see if your problem was solved. I too had problems after a rebuild, not backfireing but just would not start, turned out to be gaskets. Cause I hadnt done the leakdown test properly.
aby
Users browsing this forum: Google [Bot] and 66 guests
