by andy13 » Tue Nov 10, 2020 9:14 am
Hi guy’s, I am undergoing my first restoration. I have converted to a 12 v ignition on my LI125, not sure where the earthing points are, I have also uprated the rear brake light to an led, which has a separate earth connector. Any advice will be appreciated.
Thanks Andy
andy13
by coaster » Tue Nov 10, 2020 1:50 pm
Assuming you mean a 12 volt electronic conversion, there is a white wire coming from the stator which is your main earth and should be connected to the white connector in the CDI unit. If your LED rear light has an earth connector then it needs to be connected to the frame.
