Fork jiggeypokery
Fork jiggeypokery
Postby Scooterlam » Mon Oct 26, 2020 5:51 pm
Italian sx forks onto an indingp frame.
Will it work, gp stem transplanted
Scooterlam
Re: Fork jiggeypokery
Postby Knowledge » Mon Oct 26, 2020 11:59 pm
From the way you describe it, the SX fork stem will still be about an inch too long.
I would be tempted to buy some replacement GP forks and sell-on the SX forks to finance the purchase.
Postby Scooterlam » Tue Oct 27, 2020 8:06 pm
As it happens the SX forks are 2" short, came out of a cut down but have disc links and I have the disc hub
I've got a gp stem to weld on. Just don't fancy all the potential mix and match issues.
Read something in an old scootering about Indian gp bottom bearing cup being different.
Scooterlam
Postby Fast n Furious » Wed Oct 28, 2020 12:48 am
You could mess around no end with this only to find it easier, better and cheaper to fit the right forks for the frame.
Postby Scooterlam » Wed Oct 28, 2020 1:26 am
Maybe I should rephrase,
Is there a technical difference between Li series and gp forks other than stem length.
Scooterlam
Postby Knowledge » Wed Oct 28, 2020 8:08 am
Other than the push-in buffers of the GP forks and the length of the stem, the forks are the same as Li.
Postby Warkton Tornado No.1 » Wed Oct 28, 2020 4:38 pm
Just to add my two-pennyworth.....
Fork length conversions have existed for decades, usually shortening. The generic design between GP & SI - SIII is identical with variances only in construction of the fork link boots & buffer retention & steering 'stop' lug positioning.
My preferred means of altering the length is by use of an external tube machined to size to provide a tight fit welded into place. The alternative of a bar fitted inside works as well, but needs boring if a speedo cable &/or a hydraulic line are to be used.
To use up forks that have no other place to go, I would have no hesitation in modifying them, given a good standard of competence in engineering & welding/brazing. More so if mates are available that will do so for a pint or two. :D
