Mirror mounted on front brake pivot
Postby Knowledge » Tue Oct 06, 2020 10:20 am
Who makes/sells the rear view mirror that mounts through the pivot of the front brake lever?
Are they any good?
Re: Mirror mounted on front brake pivot
Postby Rich Oswald » Tue Oct 06, 2020 10:53 am
https://www.lambrettarestore.co.uk/
They are excellent Martin,
Postby MK Monty » Tue Oct 06, 2020 2:48 pm
They do tend to turn round in use, the temptation is to tighten them up but can stop the lever operating. I drilled down the side of the stud leaving a small stud like the woodruff key on the crank. A small cutout under the stud stops it turning round.
MK Monty
Postby Hat » Tue Oct 06, 2020 2:53 pm
https://picclick.co.uk/Lambretta-Series ... id=1&pid=2
i have one like this i picked up off ebay & love it. much less intrusive than a long stalk but does take a bit of adjusting to get right
Hat
Postby Knowledge » Tue Oct 06, 2020 6:06 pm
That is neat Mat, but I have gone with the other mirror, just because I can fit it and give the scooter back to the guy who owns it (and hopefully, get it out of my life forever)
However, next time.....
(And thanks Rich too)
Postby Tractorman » Tue Oct 06, 2020 8:35 pm
I have them on my series 2 and silver special and they are good. The S2 brake lever housing must be thinner than the special's because if you overtighten the mirror the brake lever does not return. I have overcome the mirror movement by putting a tractor rocker cover copper washer under the mirror arm.
Postby shane BBoys » Wed Oct 07, 2020 10:11 am
What is tractor rocket cover washer only ask as when I tighten mine I have the same issue?
Cheers Shane
shane BBoys
Postby Warkton Tornado No.1 » Wed Oct 07, 2020 1:49 pm
shane BBoys wrote:Tractorman
Cheers Shane
Presumably a washer on one of these :?:
https://m.youtube.com/watch?ebc=ANyPxKp ... utuD_t6QkU
Postby Tractorman » Wed Oct 07, 2020 4:14 pm
Cheers Shane
Send me your address and I'll send you one.
Just noticed a tipo in my message, it's a rocker cover not rocket :oops:
Postby Knowledge » Wed Oct 07, 2020 9:20 pm
Tractorman wrote:Send me your address and I'll send you one.
Nice one David. One man’s spare washer is another man’s life saver.
That is what this forum is all about.
