by clintcd » Fri Oct 02, 2020 7:42 pm
I am converting an Li150 S3 to DC and I have a scootopia DC light switch. Looking st the switch it appears that the pilot light will be on, even when the light switch is in the off position, is this correct. I would prefer to be able to switch it off.
clintcd
by Wack » Fri Oct 02, 2020 8:28 pm
I'd have thought if you use the yellow from the ignition switch to the bulb holder pilot terminal instead it will only come on when on the second right key position from the "OFF" position.You only need to use the handlebar switch for dip n high and horn with a key ignition.
Users browsing this forum: No registered users and 92 guests
