Five plate clutch plate options
Postby Knowledge » Tue Sep 15, 2020 4:34 pm
I have a 5 plate Surflex clutch in my 6plate clutch (a variety of different steels + one standard cork plate) but i need to think about replacing the corks following a day on the dyno.
A new Surflex 5plate is about £60, but I don’t need the steels or the springs that come in the pack.
Do Surflex do the corks on their own (I can’t find any for sale) or could I substitute the Surflex cork plates with BGM items (which are available as a set of five corks)?
Has anyone had any experience of BGM plates?
Re: Five plate clutch plate options
Postby gaz_powell » Tue Sep 15, 2020 6:04 pm
Martin
AF used to sell the thinner green surflex plates seperate, not sure if they still do.
They were for 5 plate clutches.
Gaz
Postby Warkton Tornado No.1 » Tue Sep 15, 2020 11:48 pm
CamLam list the green Surflex race variety, but presumably the cost is prohibitive. IMO they are good, specifically enabling six plates to fit, but if only scootRS were still available, I would go for that cheaper option.
CamLam also list various "corks only" kits, just in case you weren't aware.
Postby steveg » Wed Sep 16, 2020 6:35 am
Thanks to DSCScotty I use 5 standard surflex plates in my S1clutch.
I buy a pack of four and an extra pack when needed to top up.
steveg
Postby Knowledge » Wed Sep 16, 2020 7:44 am
Thanks WT1 for the lead on Cam Lam.
Steve, are Darren’s corks the standard thickness? I have been using the thinner corks from the five plate clutches and it is a lovely clutch, so I don’t want to upset the apple cart.
Perhaps Scotty will be along in a while with his contribution.
Thanks all so far.
Postby steveg » Wed Sep 16, 2020 5:15 pm
Yes 5 standard surflex plates with thinner steels, using a modified Scootrs clutch set up.
But you're right that Scotty will be able to tell you more
steveg
Postby dscscotty » Wed Sep 16, 2020 10:00 pm
they were great little clutch set ups, still a few in my own and clubmates motors, at the time, about 20 yrs ago, lol there was no decent 5 plate clutches so we developed our own, and found with a little thought and mods we could use 5 standard thickness plates and lighter springs which could cope with higher output and touring engines.
Postby Adam_Winstone » Wed Sep 16, 2020 11:19 pm
Readspeed sell thinner multiplayer corks in sets and/or individually various thicknesses available. I've used these in a number of clutches and they have functioned very well.
Postby Knowledge » Thu Sep 17, 2020 6:11 pm
Thanks Adam.
It is a shame that you can’t buy the Surflex cork plates from their 5 plate clutch without having to buy the whole kit. Cork plates do wear out, but the steels and spring should anticipate a much longer life.
Postby Wack » Fri Sep 18, 2020 7:54 pm
Readspeed red plates all day long.Available to buy individually as well.
