In-line fuel filter recommendations
I am after an in-line fuel filter for a 125.
Any recommendations?
https://ilambretta.co.uk/forum/
GExS wrote:I tried an inline filter once, it blocked up and I've never used them since but good luck using one anyway.
dickie wrote:GExS wrote:I tried an inline filter once, it blocked up and I've never used them since but good luck using one anyway.
Surely that's a good thing?
I know people are against them, but if you use a big one, it's not going to seriously restrict flow.
Has anyone ever tried the "pint per minute test"? I certainly haven't but I think I will when I eventually get some time at home.
Knowledge wrote:I am after an in-line fuel filter for a 125.
GExS wrote:Further to what I said earlier, I had a plastic one, the scooter started cutting out and gradually got worse. I couldn’t see the blockage inside the filter at first. Anyway, I took off the filter and would never use one again. There’s a filter on the petrol tap and one going into the carb so that works IMO
