Hi guys. I have put 260 miles on my new kit and there is a ride out on Sunday of around 60 miles, so far the max speed that I’ve done is About 35mph, could anyone suggest a max speed that I could take it to.
Thanks in advance for any help.
its a complete rebuild mate.shane BBoys wrote:Is it on a. Ew engine or an engine that has been run in before?
Cheers Shane.
HxPaul wrote:I have two Casa185's with new cranks and new bearings and oil seals.I have done about 200miles taking it easy and when 200 was up I ran them as normal.
dscscotty wrote:Best way to run cylinder in is to use varying speeds, lots of heat cycles at varying rpm ranges over say a 300-400 ml period, just try not to hold it at single throttle position for long periods, increase speed gradually towards max rpm as running in mls are reducing,
good luck
good luck
Users browsing this forum: Google [Bot] and 76 guests
