Rear Shocker
Rear Shocker
Postby shane BBoys » Wed Jun 24, 2020 6:04 pm
Hi.
After a lot of faffing around I’ve found the knocking on my Jet TS1, yep you’ve got it the manifold was knocking on the frame, I took the the engine mount bolt checked the eccentric cones, they were ok and had not moved. So lucky for me I had a series 2 protec shock once fitting everything is fine. The question is will the shorter series 3 protec be ok on my now ready series 2 which also has a reed valve motor, no packers as it’s a muggy with a LTH reed?
Cheers Shane.
shane BBoys
Re: Rear Shocker
Postby missing lynx » Wed Jun 24, 2020 6:12 pm
The only problem I can see is it will reduce ground clearance on the front of your exhaust
Re: Rear Shocker
Postby shane BBoys » Wed Jun 24, 2020 9:09 pm
Oh bugger I’m using a JL / KRP 4! I put it in for now and compare with the Jet!
Cheers Shane.
shane BBoys
Re: Rear Shocker
Postby shane BBoys » Thu Jun 25, 2020 4:44 pm
shane BBoys wrote:Oh bugger I’m using a JL / KRP 4! I put it in for now and compare with the Jet!
Cheers Shane.
So popped the engine in the series 2 eccentric cones with the series 3 shocker and only have 3.5 inches clearance would using a 310 series 2 shock help matters.
Cheers Shane.
shane BBoys
Re: Rear Shocker
Postby Warkton Tornado No.1 » Thu Jun 25, 2020 6:31 pm
Series 2 rear shock absorbers should definitely be used on S2 as they are longer, but also for S3 for those brave enough to need additional ground clearance ;)
Users browsing this forum: Google [Bot] and 76 guests
