Jeff t wrote:Just fitted a new layshaft and gearbox 4 speed, I have shimmed up with a 1.9 shim and the gap was less than 0.04 but still spun freely. Ordered a 1.8mm shim assembled everything including the clutch nut and the gap is still only just 0.04 so the feeler gauge just nips up. The box is really free and I can select all gears by hand. So do i buy a 1.7 shim or will this be ok. I know the recommended is 0.07 but read some stuff that says if it’s free then a smaller gap is ok but Instinct tells me to re-shim but thought I’d get other views. Top end is Imola,
tim_mason wrote:my experience with Rimini shims is that you need to measure each one as the size etched on are generally incorrect ,
Users browsing this forum: Google [Bot] and 77 guests
