First short ride, how's my plug colour
Postby neily03 » Mon Jun 15, 2020 7:55 pm
Evening all,
Just been out on my first short ride of S3 Li125 with a mugello, only did 5 miles as I wanted to stay local incase of any problems. Local speed limit is almost all 20mph so only got into 3rd a couple of time doing around 30mph.
The setup is
Mugello 186
PHBH 28
Clubman
All from Mike Pheonix and he pre-setup of the carb for my spec. Here's the plug, it's a B8
ImageIMG_1795 by Neil Schofield, on Flickr
ImageIMG_1794 by Neil Schofield, on Flickr
I know it was a very short journey so probably not the best to judge....
Looks light to me but I wouldn't call it white.....
neily03
Re: First short ride, how's my plug colour
Postby MickYork » Mon Jun 15, 2020 7:57 pm
Looks lean....I wouldn't be happy with that.
Have you done a leak test ?
Postby neily03 » Mon Jun 15, 2020 8:12 pm
MickYork wrote:Looks lean....I wouldn't be happy with that.
Yes did a leak test when I built it, was all good.
I did think it looked a little light
neily03
Postby MickYork » Mon Jun 15, 2020 8:19 pm
Probably best doing a "full" plug chop, marking the throttle at 1/8, 1/4, 1/2, etc and see where the lean spot is.
Postby neily03 » Mon Jun 15, 2020 8:34 pm
Forgot to mention it's running a Ramair filter too. Just looking at the paperwork Mike Pheonix supplied with the carb details
Main Jet - 105
Pilot - 52
Atomiser - AV266
Slide - 40
Needle - X7
neily03
Postby Scooterdude » Mon Jun 15, 2020 8:37 pm
That’s no good, you’ve got to use an old well used plug not a new one.
Scooterdude
Postby neily03 » Mon Jun 15, 2020 9:08 pm
Scooterdude wrote:That’s no good, you’ve got to use an old well used plug not a new one.
Unfortunately I don’t have an old plug to try
neily03
Postby ULC Soulagent » Tue Jun 16, 2020 1:46 am
B8 to cold for running in, B7 would be my choice until doing carriageway/ Motorway riding.
I think plug colour looks fine ;)
Postby vegansydney » Tue Jun 16, 2020 3:07 am
You need to do proper plug chops to get honest readings. There are plenty of online tutorials, such as this one. All you need is a few spark plugs, a hacksaw or a Dremel with a cutting disc, vernier calipers and a vice. Alternatively, fit a wideband UEGO sensor to read your AFR, or take it to your local 2 stroke dyno operator.
vegansydney
Postby neily03 » Tue Jun 16, 2020 4:21 pm
Thanks guys, I’ll look into do a plug chop
neily03
Postby CHRIS in MARGATE » Tue Jun 16, 2020 4:49 pm
You won't get good colour on that for a while
I think the light is not helping..
Looking for light mocha brown
Users browsing this forum: Google [Bot] and 80 guests
