LI headset has bit of play
Postby kennystag » Mon Jun 15, 2020 4:49 pm
Hi All,
My 1963 LI headset has bit of play I am thinking of overhauling what parts do i have to order to overhaul it all.
Stag
kennystag
Re: LI headset has bit of play
Postby Toddy » Mon Jun 15, 2020 4:59 pm
The parts Might be Fine it may just be the Forks Need Tightening up ?
Postby Scooterslag » Tue Jun 16, 2020 11:01 am
Had this problem a little while ago, turned out the three bolts holding my steering clamp to my headset bottom had come loose, I just replaced them with fresh nyloc nuts and all good. Paul
Postby Tractorman » Tue Jun 16, 2020 11:35 am
Scooterslag wrote:Had this problem a little while ago, turned out the three bolts holding my steering clamp to my headset bottom had come loose, I just replaced them with fresh nyloc nuts and all good. Paul
I had a Jet a couple of weeks ago with the same problem.
Users browsing this forum: Google [Bot] and 80 guests
