coaster wrote:If you look at the stator, the first coil just above the black pickup is the LT coil for the ignition, then going counter clockwise you have the 4 lighting coils which are connected together in series.
As for points over electronic, a properly set up points system is fine but the problem is that they wear and as they do so you timming gradually retards ans you lose performance. Great if you enjoy regulat maintenance, it can be quite rewarding but personally I prefer a well prepared electronic system
