Batteries
Batteries
Postby shane BBoys » Sat Jun 06, 2020 8:01 pm
Is anyone using 1 of these
https://youtu.be/-W3Tt0mgRHQ
If not what are you using?
shane BBoys
Re: Batteries
Postby Andyf » Sat Jun 06, 2020 8:52 pm
i'm still using the old B39. I'd happily upgrade to this but does it matter that my trickle charger states "FOR LEAD/ACID BATTERIES ONLY"?
Andyf
Re: Batteries
Postby Tractorman » Sun Jun 07, 2020 9:31 am
I am using a Shorai LFX09 which I bought in 2014 on the sidecar scooter. It has been no problems at all the only issue I had was when I ran it right down, left the lights on, and my regular charger would not recharge it. I took it back to the dealer and he recharged it with the special shorai charger and has been fine since. They are light and can be used at any angle.
Re: Batteries
Postby Tractorman » Sun Jun 07, 2020 9:37 am
Andyf wrote:i'm still using the old B39. I'd happily upgrade to this but does it matter that my trickle charger states "FOR LEAD/ACID BATTERIES ONLY"?
I top up my shorai battery with a standard battery charger without problems.
Re: Batteries
Postby Andyf » Sun Jun 07, 2020 2:18 pm
cool. thanks :D
Andyf
Re: Batteries
Postby vegansydney » Sun Jun 07, 2020 3:38 pm
Do you have an electric start fitted to your Lambretta? If so, I say go for it, as the high discharge is great for an electric starter (except for in subzero temps). Just make sure your rectifier/regulator suited for lithium-ion and is charging between 13.4v and 14.6v or it could be an expensive experiment. Also make sure you look up the actual amp hour ratings not the advertised 'equivalent'.
If you're looking for a 12v replacement battery for a late S2/Series 3/GP that will fit in the original tray using the original straps to hold them in place, with minimal padding, I put together this list for the LCUSA. Understandably it's a little US-centric and 2 years old now, but it may be of use.
Conventional:
    12N5-3B
    YB5L-B
    CB5L-B
AGM:
    Adventure Power UT5AL-BS
    Motobatt MB5U (if you can stomach the hideous color!)
    BikeMaster Platinum II MS-12-5-3B
Gel:
    BikeMaster TruGel MG5-3B
Lithium:
    WPS 490-2503
    BikeMaster DLFP5L-B
vegansydney
Re: Batteries
Postby shane BBoys » Fri Jun 19, 2020 11:04 pm
Tractor man, do these take a trickle charge or the dedicated charge only?
Cheers Shane.
shane BBoys
Re: Batteries
Postby Tractorman » Sat Jun 20, 2020 8:25 am
I use a standard charger but there is a note on the battery about max charge rate of 9amps. If in doubt contact Carrot cycles in Lincoln he is a main dealer for these batteries and sells them cheaper than most places. carrotcycles.co.uk 01522 595975
Users browsing this forum: Google [Bot] and 79 guests
