Rich Oswald wrote:Is it a standard top end? If so the compression shouldn't be that high. You get higher compression with kits on but if set up right with the correct cylinder head profile and the correct squish then it should be quite usable. It may just that your squish is too small and may need a thicker head gasket. Could be many things really.
HxPaul wrote:I have a Casa 185 with an li 150 gearbox,with 46x16 sprockets and its nearly impossible to kick start.
kennystag wrote:Hi All,
I forgot to say it turns over freely with the plug removed.
Stag
Skye
Andyf wrote:Would a 1mm head gasket work as an alternative?
Users browsing this forum: Google [Bot] and 76 guests
