Warkton Tornado No.1 wrote:Presuming that the crankshaft is as good as OEM (that is, not Indian with Lucky Bag big end) then the next suspect is probably the flywheel. Or even a slight misfire, especially with the plethora of badly made electronic kits fitted for, ahem, 'reliability' (Can you tell I'm not a fan?)
If you have swapped 'like for like' (as in an Indian flywheel for another) then the test may not be conclusive. "They're all made like that, Sir!"
The other thing that can catch us out is that sometimes, perhaps due to woodruff key height or other errors in manufacture, the flywheel is not always fully seated on the taper. I've had to fit other centres, concoct spacers & modify nuts, all kinds of tricks to get a good fit @ times. If a flywheel doesn't take a fair old bit of pulling (Oooer!) to remove, then it has to be made to 'fit'
ULC Soulagent wrote:Piston weight maybe![]()
Change the headset internals for mb’s brass bits, works a treat on damping vibes
missing lynx wrote:Just a thought, could it be wheel balance like in a car?
Warkton Tornado No.1 wrote:The problem still sounds to me as though it is on the crankshaft axis. Even SIP & BGM can cock up& sometimes the woodruff key can be an interference fit on height. You can chase your own tail for ages on that
I keep some that I have had to trim, step or even make from thicker material & step to remind me that we are in current day Lambretta World where quality is often only an option.
Is the front sprocket fully concentric, although clutch sprocket/clutch assemblies can run out of true?
Tractorman wrote:I never thought of starting a scooter with a drill, I have done it with smaller engines like lawnmowers. I will try that later as I not much else to do. I will take your kind offer of a 15 tooth sprocket though, please, pm how much you want for it.
Users browsing this forum: B1gD0gu3 and 124 guests
