by shane BBoys » Sun Apr 26, 2020 5:20 pm
Guys.
How can I remove this please?
Cheers Shane.
shane BBoys
by steve t » Sun Apr 26, 2020 5:49 pm
Run a hack saw blade till you are just about through then they should tap out
steve t
by rossclark » Mon Apr 27, 2020 12:51 am
They usually just tap out with a punch inside one to the inside and outside one to the outside.
by Knowledge » Mon Apr 27, 2020 10:26 pm
I think I used a socket from a socket set as a drift to ease the bushes out using a vice to push them out.
A bit of heat also helps. Done a few, and it was not as bad as it seemed it would be.
by shane BBoys » Tue Apr 28, 2020 6:39 am
Knowledge wrote:I think I used a socket from a socket set as a drift to ease the bushes out using a vice to push them out.
I’ve managed to get 1 out using a 17 mm deep socket but the inner most 1 I’ve not tried yet there not much purchase using the same socket I might see if I’ve an imperial size that’s slightly bigger.
Cheers Shane.
shane BBoys
