Sliding dog ID
Sliding dog ID
Postby Scooterslag » Thu Apr 23, 2020 12:45 pm
Just found a sliding dog in my spares and its in not bad condition though its not the most pretty of finishes, I'm guessing its a SIL but on the base is stamped NP - any idea what make it is and if its any good? would put a piccie up but can't be arsed with photobucket etc any more, thanks Paul
Re: Sliding dog ID
Postby Scooterslag » Fri Apr 24, 2020 3:50 pm
anyone?
Re: Sliding dog ID
Postby Storkfoot » Fri Apr 24, 2020 4:03 pm
I don’t but, if you are thinking of using it, run your finger along the track the bearings run on. The last SIL one I tried to use was poorly machined and caused me problems that were only rectified by replacing it entirely.
Re: Sliding dog ID
Postby Scooterslag » Fri Apr 24, 2020 4:11 pm
Storkfoot wrote:I don’t but, if you are thinking of using it, run your finger along the track the bearings run on. The last SIL one I tried to use was poorly machined and caused me problems that were only rectified by replacing it entirely.
Thanks for the advice dude, yeah its pretty rough finish wise so might give it a miss , cheers again
Re: Sliding dog ID
Postby Cgt75b » Fri May 15, 2020 6:47 pm
Yes it’s a SIL one, I’ve got one the same in a box from Lucknow.
Users browsing this forum: No registered users and 160 guests
