knighty wrote:I think from all of your comments I am beginning to doubt the quality of the sliding dog. I bought it from one of the well known traders via ebay but it was not the most expensive available!!!. It is of course possible that I loaded 3rd gear the wrong way round but I doubt it as I am normally quite methodical. I think I will strip the box and have a good look at it - I have a spare LI 150 motor complete so perhaps I should nick the box from that as I know it works - I will take the layshaft as well so it will only need shimming.
I will take the opportunity to see if I can improve the clutch feel as it is a 5 plate readspeed set up and is bloody heavy - I have a Rayspeed cassette in another scoot and the readspeed one feels heavier and I am using the reedspeed springs.
Thanks a lot for your comments and I will post an outcome when I fix it.
Warkton Tornado No.1 wrote:
I haven't been using the ST90 type oil for nearly a decade now & have to say there are much better alternatives IMHO
What gearbox oil do you use please? I did try some synthetic oil years ago when the carbon clutches were made and what a waste of time they were. I never continued trying the synthetic oil.
yes mine creeps when cold using SAE90 but within 2 minutes of riding is fine at the junction when I have to stop and set off again, but it’s the initial start up from cold and clonk into gear I don’t like so am keen to give ATF a go.Warkton Tornado No.1 wrote:Dexron III is the stuff I use, but there may be something even better.
I meant to say that in use, my clutches fitted with ATF have no tendency to 'creep' with the clutch lever pulled in, not even from cold with the generic Lambretta type with six plates squeezed in standard components, the only modification being to the crownwheel slot depths if necessary. I'm also fussy about the spring gauge & fully compressed height of the set, to ensure getting coil bound is avoided & consistency'of them in action.
However, my usual practice is to set the clutch release arm toward the rear of the engine to give more leverage. Setting it 'square' gives the least movement if you think about it
Scooterdude wrote:
As i look at the clutch cable adjuster it strikes me it would work better if the position of the block was further inbound with the cable routed behind the engine mount and with that kink taken out of it so the inner doesn’t rub on the adjuster if you see what I mean.
Users browsing this forum: B1gD0gu3 and 125 guests
