Sip rim on scootopia hub
Postby gizmo » Fri Apr 03, 2020 6:31 pm
Sip rim on scootopia rear hub. Has anyone else found these really tight.
gizmo
Re: Sip rim on scootopia hub
Postby Tractorman » Fri Apr 03, 2020 7:36 pm
Yes, I sorted it out with my Dremel.
Postby Toddy » Fri Apr 03, 2020 7:43 pm
gizmo wrote:Sip rim on scootopia rear hub. Has anyone else found these really tight.
I had one that wouldn’t fit on standard rims two off the studs were off centre :shock: returned to dealer
Postby Vega125s » Mon Apr 06, 2020 10:24 am
Just got one , a little disappointed ,light surface rust and the SIP rims have to be forced on!
So dremmel time or send back?
Why can’t they get these things right ? the SIP rims are beautifully made and over the years I have never known fitting problems.
Vega125s
Postby gizmo » Mon Apr 06, 2020 12:08 pm
You really would not think it would be a problem getting it right. I have used a sil hub with no issues. I have had more niggly little issues with this rebuild than ever. Even the ally floor channel holes didn't line up. Easily sorted but unnecessary. I have taken a little off the hub. Not a lot. Just annoying as its been sprayed. Even lengths of cables vary between manufacturer. Why. Tell I'm stood down for a month time to moan :lol:
gizmo
Users browsing this forum: B1gD0gu3 and 127 guests
