by shane BBoys » Thu Apr 02, 2020 9:21 am
Just noticed that the stub, bolt for the horn is missing or cut off at some point I’m guessing I can centre punch drill and tap it what size tap would be required.
Cheers Shane.
shane BBoys
by Norrie Bodge » Thu Apr 02, 2020 3:25 pm
shane BBoys wrote:Just noticed that the stub, bolt for the horn is missing or cut off at some point I’m guessing I can centre punch drill and tap it what size tap would be required.
Cheers Shane.
Drill & Tap to m6
Norrie Bodge
by shane BBoys » Thu Apr 02, 2020 5:50 pm
It just taken me an hour to find my tap n die set, I thought it was in the conservatory where I’d last used it but no it was in the garage on top of the over spill ( beer ) fridge, so will sort it tomorrow between painting some bits for this build.
Cheers Shane.
shane BBoys
by gaz_powell » Fri Apr 03, 2020 7:31 am
My API S2 never had anything. Just drilled and tapped frame and put a spot weld on it for good measure
by shane BBoys » Fri Apr 03, 2020 6:47 pm
gaz_powell wrote:My API S2 never had anything. Just drilled and tapped frame and put a spot weld on it for good measure
I’ve drilled and taped the square plate where the stub- bolt must have been, the frames already powder coated so welding is not and option.
Cheers Shane.
shane BBoys
Users browsing this forum: B1gD0gu3 and 139 guests
