Coffee time
Spent last hour trying to get rubber round legshield toolbox. No wonder innocenti never fitted them. Calm down and coffee time. Big dollop of metal flake not helping
https://ilambretta.co.uk/forum/
I went rubberless a couple of times and paid ever sinceKnowledge wrote:I gave up in the end. Mine fitted fine rubberless.
gaz_powell wrote:I normally put masking tape on to hold it place then as you fit to legshield carefully pull it off. That's what I ended up doing in end after filing bits off were the fibreglass was a bit thick
I've recently used a metal reinforced rubber on one - so easy! Hid a few sins aswell!
MickYork wrote:I welded mine on.....filled and sprayed, no rubbers, seamless joint.
