I went rubberless a couple of times and paid ever sinceKnowledge wrote:I gave up in the end. Mine fitted fine rubberless.
gaz_powell wrote:I normally put masking tape on to hold it place then as you fit to legshield carefully pull it off. That's what I ended up doing in end after filing bits off were the fibreglass was a bit thick
I've recently used a metal reinforced rubber on one - so easy! Hid a few sins aswell!
MickYork wrote:I welded mine on.....filled and sprayed, no rubbers, seamless joint.
