Speedo drive thread size
Postby Tractorman » Mon Mar 30, 2020 11:11 am
What is the thread size of the speedo bush that hold the worm drive in, please? The hub has been at the powder coaters and the threads are clogged with paint and it's hard.
Re: Speedo drive thread size
Postby gizmo » Mon Mar 30, 2020 11:31 am
M14x 1.5 pitch I believe
gizmo
Postby Tractorman » Mon Mar 30, 2020 11:46 am
Thanks, but the appears to be thread 16mm but not sure about the pitch.
Postby bike grim » Mon Mar 30, 2020 12:29 pm
Sure it’s the same as the side casing oil plugs
Postby Chadley » Mon Mar 30, 2020 2:34 pm
A quick look in my notebook shows I previously measured one as M16 x 1.5mm.
Chadley
Postby martyn dwane » Mon Mar 30, 2020 8:30 pm
the side casing plug hole is M16 x 1.5, as i had to buy a tap recently fo clear the threds on one.
im positive the speedo drivebush is M14 x 1.5 as i purchased a tap to clear the threads after powder coating a hub, many years ago.
The "nut" that screws onto it is M12 x 1.00mm.
martyn dwane
Postby ULC Soulagent » Tue Mar 31, 2020 12:20 pm
bike grim wrote:Sure it’s the same as the side casing oil plugs
It is Gareth, just tried it on a S3 stainless type but on brass version it wouldn’t :o
Postby Tractorman » Thu Apr 02, 2020 4:38 pm
Can confirm m16x1.5, thanks for your help.
Users browsing this forum: fredste and 67 guests
