by Revvers » Wed Mar 25, 2020 9:14 am
Hello all. I’ve bought an Oiltek hidden reservoir in order to give my front inboard disc brake a bit more oomph. The fitting instructions show fitment to an outboard one. Can you use it on an inboard and can someone explain how to do it please? I’m not mechanically gifted, but would like to try fitting it myself. Thank you
Revvers
by matthew » Wed Mar 25, 2020 10:47 am
I assume your inboard disc has at some point had a hydraulic conversion?
matthew
by Revvers » Wed Mar 25, 2020 12:02 pm
No it hasn’t. Have I bought the wrong thing?
Revvers
by matthew » Wed Mar 25, 2020 12:20 pm
I'm afraid so. The Oiltek hidden master cylinder / reservoir is for hydraulically operated braking systems. Your brake must be cable operated. A reverse pull cable conversion may improve your inboard front disc brake but alas the hydraulic reservoir will have no benefit.
matthew
by Revvers » Wed Mar 25, 2020 12:24 pm
Thanks Matthew. Appreciate that
Revvers
by rossclark » Wed Mar 25, 2020 8:41 pm
You can get a pop in hydraulic slave cylinder that goes in the same hole as the cable actuator and is held in place by the circlip. Frankly they're a bit hit and miss it's better to get it converted properly for hydraulic operation if anyone still does it. MB maybe. But that is a one way process and you might think twice about doing that to an original brake.
by dickie » Thu Mar 26, 2020 8:41 am
You can buy the backplate with slave cylinder fitted on its own.
I think beedspeed do them for around £100.
by HxPaul » Thu Mar 26, 2020 9:10 am
Users browsing this forum: Nudger and 88 guests
