CHRIS in MARGATE wrote:You need only 3 things.
Ignition... good spark?
Fuel ..... new petrol. Keep throttle shut when kicking
Compression .... woolly you say? Do you know anybody with a compression tester? Invaluable.
Did you measure ring gap?
Is the clutch ok?
Try a squirt of Easy Start.... that will start a WW1 tank!
sunrisemac wrote:try putting a squirt of oil down the bore and turning it over a few times to seal piston to bore then put plug in and try again
St George wrote:I had a non starter, it had a spark when out of head but it failed under compression. Faulty CDI ?
martyn dwane wrote:The engine had a 3 ring knackered piston which I changed to a 2 ring as the only 2 ring I could find was for an LD.
not got the wrong piston in there have you ?
i remember a mate building a engine from boxes of bits he bought, it wouldnt start for love or money when we took the cylinder head off and turned it by hand over the piston never came to the top of the bore , cant remember if he used a series 1 piston in a series 3 barrel
CHRIS in MARGATE wrote:It won't matter if it's 2 or 3. If the bore is worn a new piston won't cure your problems. You will need to have the barrel rebored and fit an oversize piston. There are lots available. Best to get the oversize piston and ask a machine shop to bore to the appropriate size.
pg42 wrote:CHRIS in MARGATE wrote:It won't matter if it's 2 or 3. If the bore is worn a new piston won't cure your problems. You will need to have the barrel rebored and fit an oversize piston. There are lots available. Best to get the oversize piston and ask a machine shop to bore to the appropriate size.
Cheers, that's where i'm going.
Users browsing this forum: No registered users and 172 guests
