Warkton Tornado No.1 wrote:Regardless of the fork manufacture, the links, rebound rubbers (if fitted, which they are not always, as in some race machines) & springs/fully extended damper length all need to be pairs.
That said, even after build, checks should also be made with rider seated.
Finally, if using SIP rims (the safest that I am aware of due to their hub centralising design not relying on four M8 studs!) do be aware that they offset the wheel IMO.
Users browsing this forum: No registered users and 174 guests
