Daft Question Time
Daft Question Time
Postby ToBoldlyGo » Thu Dec 26, 2019 10:41 pm
Are the dampers fitted on the S2 TV175 the same length as those used on the S3? I thought they would have been personally. But I've seen them advertised seperately and I wondered why?
Re: Daft Question Time
Postby vegansydney » Fri Dec 27, 2019 2:47 am
Series 1 TV and Series 2 TV dampers are noticeably skinner than Series 3 TV, SX and GP/dl dampers. While the shape of the fork links (and corresponding ride height) also differ, the most obvious difference in the dampers is the girth.
vegansydney
Postby shane BBoys » Fri Dec 27, 2019 8:40 am
I’m no expert but they are the same length, an adult will be along when they get up to clarify!
:D
Cheers Shane.
shane BBoys
Postby ToBoldlyGo » Fri Dec 27, 2019 2:45 pm
Scootopia sell the skinny dampers for the S3. Probably a little too skinny maybe. Curiously the S2 dampers are fatter with a bit more room around the tube.
Postby bookertmgs1 » Sat Dec 28, 2019 5:53 pm
ToBoldlyGo wrote:Scootopia sell the skinny dampers for the S3. Probably a little too skinny maybe. Curiously the S2 dampers are fatter with a bit more room around the tube.
I’ve seen that too the scootopia Tv1&2 dampers look fatter than the S3 ones - the dampers on my TV/2 are wider than a set of slim escorts
Does anyone have the definitive answer?
bookertmgs1
Postby vegansydney » Fri Jan 03, 2020 2:55 am
L - R: Genuine TV/2, GP/dl (stamped 9/1968), Eibar Jet (stamped JUNIOR)
Diameter at bottom: TV/2 20mm, GP/dl 22.25mm, Eibar 22.25mm
Eye-to-eye (fully extended): 245mm, 245mm, 240mm
vegansydney
Postby ToBoldlyGo » Fri Jan 03, 2020 1:38 pm
Cheers for posting that. Looks to me like the ones Scootopia sell for the S3 are a dead ringer for the GP. Pretty much as I suspected though, they are the same length as the S2. A little tid bit of information that might come in useful.
Postby dave999 » Fri Jan 03, 2020 5:14 pm
seems like a very good question
I learn something new every day
dave999
Postby vegansydney » Fri Jan 03, 2020 6:22 pm
ToBoldlyGo wrote:Cheers for posting that. Looks to me like the ones Scootopia sell for the S3 are a dead ringer for the GP.
Welcome! Italian GP/dl dampers are the same as Series 3, it's the TV Series 1 and 2, that are different from the rest of Italian production. I found it interesting that Eibar Jet ones were the same size as S3/GP/dl but slightly shorter, but I'll be the first to admit I know nothing about Spanish Lambrettas.
vegansydney
