by kennystag » Tue Oct 29, 2019 10:43 am
Hi all,
I have a problem with my GP i left it lying for a about 4 months i went to start it and it only turns half way and stops, i turned the flywheel in both directions with the plug out still the same, any pointers.
Stag
kennystag
by Scooter Paul » Tue Oct 29, 2019 1:40 pm
If everything was ok when you laid it up and there were no pending mechanical faults then I would suspect some corrosion has developed in the barrel. This would form a barrier that the rings couldn’t pass. Another possibility, albeit I’ve never seen it on a small engine is that a mouse has crawled in and it’s blocking the piston!
Scooter Paul
by St George » Tue Oct 29, 2019 4:33 pm
May be worth looking inside the ports, pain in the bum I know.
St George
by Fast n Furious » Wed Oct 30, 2019 10:19 pm
Those cheap endoscope cameras off fleabay that connect to your smart phone can be useful here
Maybe you know someone that has one?
