Crank change without engine removal?
Postby Hughieboy » Thu Oct 17, 2019 9:04 pm
Just contemplating my first crank change...
I’ve read up about it, freezing the bearings and heating the casing etc but all the photos and videos I’ve seen show it done with the engine out and on its side. I can see that dropping things in and knocking them out on a solid surface vertically is preferential but is it simple enough with the engine in, ie horizontally? Or is that asking for trouble? I was also wondering if I’ll save myself a ton of grief buy buying the pullers and drift for getting the bearings in and out.
Any advice on this gratefully received :D
Hughieboy
Re: Crank change without engine removal?
Postby Knowledge » Thu Oct 17, 2019 9:30 pm
It is possible to change the crank and bearings with the engine in the scooter.
Postby coaster » Thu Oct 17, 2019 10:03 pm
Knowledge wrote:It is possible to change the crank and bearings with the engine in the scooter.
Agreed it is certainly possible but a lot easier on the knees if you drop the engine out to do it imho. You can get the crank out and back in without special tools but its quite easy to damage your old crank getting it out if you knock it out with a hammer so a crank puller/removal tool would definitely help.
Postby Hughieboy » Thu Oct 17, 2019 10:40 pm
Thanks guys...
I should have added, I have a ramp so won’t be rolling around on the floor! I was more thinking of the angle of access. I’ll get some correct tools! :D
Hughieboy
Postby Scooterdude » Fri Oct 18, 2019 5:53 am
Yes easy enough to do in frame on bench just get a crank pusher/extractor and a con rod holding tool first, last time I looked Lambretta upgrades were the best on price.
I’m guessing you already know about using your drive bolt and drive sleeve to draw the new crank into position.
Scooterdude
Postby Hughieboy » Fri Oct 18, 2019 7:16 am
Scooterdude wrote:Yes easy enough to do in frame on bench just get a crank pusher/extractor and a con rod holding tool first, last time I looked Lambretta upgrades were the best on price.
I read in Sticky’s book about that... but hadn’t worked out how to do it yet. I imagine it’s simple enough? I’ll get the other tools, it’s been recommended that I get a bearing pusher/puller as well but they’re quite pricey...
Hughieboy
Users browsing this forum: nastro azzurro and 53 guests
