Quick wiring problem.
Postby St George » Tue Oct 08, 2019 12:34 pm
I have fitted a new spare engine in my scoot ( series 3 SIL ) I have wired the three wires direct from the stator and it's running fine. Which of the wires should be connected with the ignition switch to cut the engine off. Looking at Sticky's collected of diagrams the green wire seems to be the best option which comes out of the loom near the back wheel. Thanks.
St George
Re: Quick wiring problem.
Postby Scooterdude » Tue Oct 08, 2019 1:40 pm
On your cdi you should have a white, a red and two green terminals so the white, red and green from your stator go direct to the corresponding colours there and the second green terminal is your green wire return to your kill switch/ignition switch.
Scooterdude
Postby St George » Tue Oct 08, 2019 2:49 pm
That's makes sense, thanks.
St George
Users browsing this forum: nastro azzurro and 48 guests
