by Norrie Bodge » Mon Oct 07, 2019 10:09 pm
Has anyone used a S3 type hydraulic brake switch unit On a S1/2 ?
This is for a mate who gotta winter S2 project & With the S1/2 being of a larger diameter
he’s asking can we use the hydraulic brake setup off his 83 Spanish LI ?
Has anyone did this ! as We believe it’ll need machining or reaming out to fit so which is the best way forward...
Norrie Bodge
by Toddy » Tue Oct 08, 2019 5:59 am
As you say it will take some fettling to fit due to the tapers , you can buy the housing seperate without the master cylinder then attach his master cylinder the rest of the brake should fit ok .
by gaz_powell » Tue Oct 08, 2019 5:54 pm
Before the glut if SSC, ScootRS and Spaq master cylinder mounts there was the MBR one, they were made originally for italian bars.
I pain stakingly opened one out by hand to fit Indian larger bars.
If theres enough meat on it, cant see why not.
As said what price is a S2 one (40 quid) against your time and potential to cock it up.
Use all the other parts and sell tbe S3 mount
Users browsing this forum: nastro azzurro and 59 guests
