Side Panel Damage
Side Panel Damage
Postby LambrettaRuss » Thu Sep 04, 2014 10:12 pm
Can anyone tell me if this is recoverable?
Not sure how it happened (the little bracket part was wired to the panel when I got it).
Obviously needs welding and straightning, but is it going to be a pig to get it all aligned?
LambrettaRuss
Re: Side Panel Damage
Postby Bettagetabrettabolti » Fri Sep 05, 2014 6:44 am
Definitely recoverable - see a good panel beater.
I had a car run over a S2 panel that fell off mine - literally right through the centre of it - and you can't see any trace of it.
Luckily for me Carole Nash paid for it!
Bolti
Postby LambrettaRuss » Fri Sep 05, 2014 4:24 pm
Cheers Bolti.
Want to keep the panels as they appear original to the scooter.
LambrettaRuss
Postby daniel whiteley » Fri Sep 05, 2014 6:24 pm
yes that should easy repair , if you were closer i would have done it you , just find a good tinbasher and he should easy knock it into shape and mig the bracket back on
daniel whiteley
