Exhaust options
Exhaust options
Postby Mattc series3 » Wed Oct 02, 2019 8:23 pm
Hi all,
I am looking at what exhaust options are open to me. I have a standard series 3 Li 150 and want to put a chrome/stainless finished exhaust on. I am about to have the chain case polished to a mirror finish and wanted the exhaust not to look so dull. The scooter shop i enquired in ( Allstyles ) suggested i might go for something like a clubman big bore and have it plated as i was looking to keep the standard look.Does anyone else have any suggestions on other ways could go?
Thanks in advance,
matt
Mattc series3
Re: Exhaust options
Postby ToBoldlyGo » Wed Oct 02, 2019 9:53 pm
Don't listen to them. If you've got a standard LI150 the last thing you want to do is stick a Clubman on. That would kill it stone dead. You are pretty much limited to a standard exhaust. But of course you can plate it, or not, as you see fit.
Re: Exhaust options
Postby Mattc series3 » Thu Oct 03, 2019 4:54 am
Thanks for your reply, I didn’t realise fitting a big bore would have an adverse effect. I will look into the plating to see if it is a viable option, if I do go that route I would use a new exhaust so any recommendations on make or supplier?
Mattc series3
Re: Exhaust options
Postby ToBoldlyGo » Thu Oct 03, 2019 11:02 am
There is nothing wrong with the Clubman as such. But your 150 won't produce enough power to make it go. It will work, but it would be gutless. Try the Scootopia or Casa exhaust. They both do nice standard exhausts.
Re: Exhaust options
Postby lam1962brettagg » Thu Oct 03, 2019 8:26 pm
yes agree
I was given a big bore by a 'reputable supplier' and told it was just a replacement for the standard.
never ran right and binned that exhaust replaced it with a casa standard.
p.s li 150 standard
lam1962brettagg
Re: Exhaust options
Postby vegansydney » Thu Oct 03, 2019 11:53 pm
If you’re going to the effort of plating and/or polishing the exhaust, I’d highly recommend you purchase a Tutto Lambretta exhaust over the Casa one, as the difference in quality is significant, while the price difference is marginal. I speak from experience.
The Tutto Lambretta exhausts are also a better fit than the Scootopia ones. Can’t find a local supplier? STF are Tutto/Stratos retailer and you can also buy direct for ~€120. I’ve had good experience buying from both.
Looking for a little extra performance, drill out the mushroom baffle as per the ‘60s Tuning Manual or remove it completely.
vegansydney
Re: Exhaust options
Postby ToBoldlyGo » Fri Oct 04, 2019 7:50 pm
It's always worth remembering though. If you buy yourself an exhaust with the intention of chroming it then you are probably looking at double the price just like that.
Re: Exhaust options
Postby Scooterdude » Fri Oct 04, 2019 7:53 pm
There are some clubbies for sale on eBay already chromed, not sure of the quality though....
Scooterdude
Re: Exhaust options
Postby Mattc series3 » Fri Oct 04, 2019 8:23 pm
Thanks for all the replies, I fully understand that it probably will cost loads more than say a Stirling or something like that that is already chrome/ stainless but that needs further modifications to my standard set up. For me I like the look of a standard scooter but want to just put a little of my own spin on it to make it mine.
I have seen the already plated clubmans on eBay but I have to say rightly or wrongly I am concerned about the Indian quality!! My heart says try one it’s the look you want but after the above comments on a clubman with a standard set up my head,for once, says put the £125 or so into buying a new scootopia/ Casa and look at the plating option. I am hoping to visit the plating company in the next couple of weeks so will update when I know if it can be done.
Thanks again.
Mattc series3
Re: Exhaust options
Postby rossclark » Sat Oct 05, 2019 9:36 pm
Don't fit it and run it if your thinking of plating it some places won't touch them if they're 'used'
Re: Exhaust options
Postby Mattc series3 » Sun Oct 06, 2019 6:51 pm
No,the idea was a new exhaust for that reason, I’ve already had one company say they can’t do it, got some more to try but it might be a wasted exercise.
Mattc series3
Re: Exhaust options
Postby ToBoldlyGo » Sun Oct 06, 2019 7:37 pm
You could always try chrome powdercoat.
Re: Exhaust options
Postby Mattc series3 » Sun Oct 06, 2019 8:46 pm
Hadn’t thought of that, I’ll see if I can find a picture of the finish on the net, cheers
Mattc series3
Re: Exhaust options
Postby bookertmgs1 » Sun Oct 06, 2019 9:58 pm
You could have an exhaust ceramic coated - cost about £140
Doesn’t last really but obviously dependant on how many miles you do. I got about 5/6k out of the coating before it started to look tired. If you are that bothered just spray regularly
bookertmgs1
Re: Exhaust options
Postby Mattc series3 » Sun Oct 06, 2019 10:28 pm
I’ve just found this from a company in Hull that do their own plating, http://shop.qualitychrome.co.uk/clubman-exhaust,
Only problem being it’s a clubman and some say they don’t work with a standard set up which I have. I have mailed them to get a quote on plating a standard scootopia one, so I’ll see how the prices compare.
Mattc series3
Re: Exhaust options
Postby burnside » Tue Oct 08, 2019 10:46 am
ToBoldlyGo wrote:You could always try chrome powdercoat.
I had a BGM clubman Cermakromed by Camcoat a few years ago, not as shiny as Chrome but a nice finish and is lasting really well. I think I paid somewhere between £100-150 for it but when I contacting them just over a year ago to ceramic coat an expansion pipe they were looking for around £200 just for black, ended up getting it done elsewhere for £90
burnside
Re: Exhaust options
Postby Mattc series3 » Tue Oct 08, 2019 12:21 pm
I have just been emailed back by qualitychrome of Hull ( the people that sell the clubman ) and they are the only people that are willing to chrome plate it, I have a new scootopia and a few other bits being packed up to be sent to them, not a cheap job but at least I can use the original parts although they will be coated.
Mattc series3
Re: Exhaust options
Postby burnside » Tue Oct 08, 2019 3:45 pm
Mattc series3 wrote:I have just been emailed back by qualitychrome of Hull ( the people that sell the clubman ) and they are the only people that are willing to chrome plate it, I have a new scootopia and a few other bits being packed up to be sent to them, not a cheap job but at least I can use the original parts although they will be coated.
I've not had any parts chromed by them but I have bought some of their chrome rims and they do live up to their name so not a bad choice, won't be cheap but you get what you pay for
burnside
Re: Exhaust options
Postby Watfordwhite » Tue Oct 08, 2019 5:59 pm
Always a nice job from quality Chrome.
Watfordwhite
Re: Exhaust options
Postby Mattc series3 » Tue Oct 08, 2019 7:36 pm
I was not scared off by their price, I know there is plenty out there that will say it’s a waste but it’s the look I’m after, they are also chroming my original stand,splash plate and polishing my crankcase, yes I know you can buy a stainless stand but I have had two now and they are both too long despite being assured that they were the same as the original. At least I get to keep the original bits all be it blinged up a bit.
Mattc series3
