Scooterdude wrote:Try stripping the gearbox completely out then put the Christmas tree back in and twirl with your fingers, does it rub? If so keep adding shims until it doesn’t.
Is it a poorly made aftermarket Christmas tree I wonder? Can you borrow another to try?
No it shoulden't do.lam1962brettagg wrote:Scooterdude wrote:Try stripping the gearbox completely out then put the Christmas tree back in and twirl with your fingers, does it rub? If so keep adding shims until it doesn’t.
Hi
thanks for the reply.
the xmas tree will rub anyway when fitted on its own
lam1962brettagg wrote:I marked the casing with permanent marker behind the xmas gear last time it made a noise. now found a big circular score mark which cuts through the marker pen too.
Users browsing this forum: nastro azzurro and 59 guests
