Lambretta series 3 Battery Strap Attachment
Postby scrag68 » Tue Sep 24, 2019 5:15 pm
Afternoon Guys - does any have any images or information on how the battery strap attaches across the battery on a Series 3 please? its the other side of the attached picture i'm interested in TIA.
scrag68
Re: Lambretta series 3 Battery Strap Attachment
Postby Warkton Tornado No.1 » Tue Sep 24, 2019 7:35 pm
The standard strap should have a large 'pin' in it that should be free to rotate. The ends are cranked & register in the two holes in the battery tray. There is no guarantee that it will stay located in the tray whilst the faff of fitting the battery & strap over it, so I nowadays put a small piece of tight fitting fuel pipe on each end of the pin to keep it in place.
I hope you can understand my explanation ;)
Postby landybretta » Tue Sep 24, 2019 7:36 pm
]The trunnion on the end of the battery strap slots into the 2 holes on either side of the battery tray at the rear.The strap can slip out until fastened at the front when the battery is fitted.
landybretta
Postby scrag68 » Tue Sep 24, 2019 8:47 pm
Thanks Guys for the replies its much appreciated, your replies make sense, my battery tray is welded to the frame I don't recall seeing the 2 holes to locate the rod but I may have been over thinking it so will double check. thanks again.
scrag68
