Headlight
Headlight
Postby Scooterlam » Wed Aug 14, 2019 7:40 pm
Is the bulb/lamp H6?
Scooterlam
Re: Headlight
Postby Fast n Furious » Wed Aug 14, 2019 7:44 pm
Standard lammy headlamp bulb is a Ba20d prefocused.
Re: Headlight
Postby Scooterlam » Wed Aug 14, 2019 7:51 pm
On flea Bay ba20d and h6 are the same.
Anyone had any luck with cob leds?
Scooterlam
Re: Headlight
Postby rossclark » Wed Aug 14, 2019 9:44 pm
Re: Headlight
Postby Fast n Furious » Thu Aug 15, 2019 12:49 am
I think H6 is some Chinese generated number. Probably uses Ba20d dimensions without having to refer to its original British design origins.
H6 is not a format you will see in western bulb catalogues as far as I can tell.
Most of these bulbs are useless in a lambretta cos the lammy headlamp requires a pre-focused bulb to direct the light onto the right space of road.
The cheap fleebay ones just project all over the place but are great for blinding oncoming drivers. :o
Re: Headlight
Postby Donnie » Mon Aug 19, 2019 10:35 am
rossclark wrote:I'm running one in my Lince
https://www.scooterotica.org/forum/view ... =7&t=40383
Have you any photos of the inside of the headset after fitting?
Donnie
Re: Headlight
Postby rossclark » Mon Aug 19, 2019 7:17 pm
You can't really do that with the lince as the headlight goes in last and is screwed to the fibreglass cover. In theory the heatsink etc. is not supposed to be any deeper than the three pin connector.
Re: Headlight
Postby Donnie » Fri Aug 23, 2019 1:01 pm
ah ok, didn't actually know that about the lynx i have to admit. :D
Donnie
Re: Headlight
Postby rossclark » Mon Aug 26, 2019 11:30 pm
Next time I have the headset off I'll take some pics of the loom surgery.
Users browsing this forum: nastro azzurro and 47 guests
