DC/AC
Any potential issues (or advantages) connecting a DC stator in AC wiring/configuration?
https://ilambretta.co.uk/forum/
rossclark wrote:Wiring is wiring. You'll need to change your horn and fit a rectifier rather than a regulator and either a battery or a capacitor. Other than that there's no real problem.
dickie wrote:Or just ground one of the 2 yellow output wires from the stator and it becomes an ac stator
Ranburetta wrote:Thanks all.dickie wrote:Or just ground one of the 2 yellow output wires from the stator and it becomes an ac stator
I have gone down the DC stator route which for the time being I shall be running AC until I can swing the other way!
PS where can I buy DC lamps?
dickie wrote:Ranburetta wrote:Thanks all.dickie wrote:Or just ground one of the 2 yellow output wires from the stator and it becomes an ac stator
Sorry, I'm confused. Are you saying that you've bought a DC stator and want to convert to full DC? I thought you meant you had a DC stator but wanted to retain your AC system?a
Ranburetta wrote:
In the light of helpful advice on here and elswhere I have bought DC and am currently using it in AC mode with the option to swing to DC/Wassell if and when I get the time!
In which case you dont need to any wiring alteration to the loom other that connecting of the 2 yellows to a good earth as already mentioned
Think that's one yellow to ground
