protec rear shock
protec rear shock
Postby bluebob » Sat Jun 15, 2019 10:34 pm
some time ago I read that it is advisable to put washers behind the protec shock absorber aswell as the usual washers.anyone know if this is correct and why?
bluebob
Re: protec rear shock
Postby shane BBoys » Sun Jun 16, 2019 6:24 am
Hi.
I have on mine but I’m sure the rule is to have the centre of the shocker in line with the rear of the body work!
Cheers Shane.
shane BBoys
Postby bluebob » Sat Jun 22, 2019 11:04 pm
now took delivery of shock absorber and found it has to be packed off at the back to push spring away from rear mudguard.the bush is not as wide as original so spring fouls on damper if not packed off.those spare clutch shims are perfect for the job.
bluebob
