I have used Petseal in the past, and it has flaked off inside the tank. I know others have had the same problem.
Does anyone know of a better product?
col68 wrote:Think I would treat myself to a new tank
Knowledge wrote:I have used Petseal in the past, and it has flaked off inside the tank. I know others have had the same problem.
Storkfoot wrote:Search for Tankcare Products. They even do a Petseal Remover too which probably tells you all you need to know about that particular product.
I have only used Tankcare on 2 tanks that both needed welding. This is why I used it. In both cases, with correct preparation, the tanks sealant is still sound years later.
Norrie Bodge wrote:Knowledge wrote:I have used Petseal in the past, and it has flaked off inside the tank. I know others have had the same problem.
POR15 I used as recommended by Ben at AF
3 years on & Been ok so far
Users browsing this forum: No registered users and 96 guests
