Atomic Performance clutch parts
Postby Knowledge » Mon Jun 03, 2019 11:15 pm
I am after an Atomic clutch pressure plate. I know they aren’t made any longer, but does anyone have one spare or know where I can buy one?
I have already reached-out to Martin Hyland/Corrado/Just Lambretta, who used to stock them. I look forward to his reply.
Re: Atomic Performance clutch parts
Postby nsaints » Tue Jun 04, 2019 1:07 pm
can't help you with the pressure plate afraid
on the subject of Martin/Just Lambretta contact - I'm finding email contact doesn't seem to work
I tried myself and never received a response
However order something from the website and it does turn up
adding the above in-case Martin reads this
nsaints
Postby Knowledge » Tue Jun 04, 2019 2:14 pm
To his credit, Martin Hyland did respond to my message via Facebook Messenger.
He is checking his vaults in case he still has one, but he was not hopeful.
You are right though, his postal delivery is very sharp.
Postby nsaints » Tue Jun 04, 2019 11:10 pm
Agreed
Added my message Incase Martin didn’t realize there was some email issue going on he wasn’t aware of
nsaints
Postby Norrie Bodge » Wed Jun 05, 2019 1:56 pm
This anygood m8, from Beedspeed mind so ??
https://beedspeed.com/products/lambrett ... te-deep-gp
Norrie Bodge
Postby rossclark » Wed Jun 05, 2019 5:40 pm
Norrie Bodge wrote:This anygood m8, from Beedspeed mind so ??
They can't get the right picture what chance they'll send the right part? :lol:
Postby Adam_Winstone » Wed Jun 05, 2019 6:52 pm
I could do with trying to source one (or 2) of these also as I bought a couple of the billet centres a few years back and didn't initially twig to the fact that the spring seat recesses are not quite in the standard radius from centre, meaning that when you use them with a standard pressure plate the springs are not aligned top and bottom. As such, the springs do not compress straight as top and bottom have different centres :cry:
I've never had an Atomic pressure plate so cannot say with any certainty that this will correct the alignment but I'd love to think that it would (?).
Knowledge, if you get offered a number of these, please put me on to any spares available?
Ta
Postby Knowledge » Wed Jun 05, 2019 9:18 pm
I have just compared my Atomic pressure plate and the centre spider, and the five spring holes line-up very badly indeed.
Having said that, my clutch is very good for 28ft.lbs. Light in operation with the six plates.
If I am inundated with offers Adam, I will let you know.
Postby Norrie Bodge » Wed Jun 05, 2019 9:34 pm
Knowledge wrote:Will do Adam. ;)
& me plz knowledge m8
Norrie Bodge
Postby Knowledge » Wed Jun 05, 2019 11:47 pm
I have taken a deep breath, and ordered one from Beedspeed. Thanks for the tip NB.
However, I am still on the lookout for one of the Atomic items.
Postby Norrie Bodge » Thu Jun 06, 2019 12:39 am
A mate recommended these & said worked fine!
Also says he used to get some extra weld put on the top of the legs where they meet the top plate..
I’ve emailed Pat Joynt at SSC asking 2 see if he can help get any of Atomic types ;-)
Norrie Bodge
Postby Knowledge » Thu Jun 06, 2019 6:43 am
Norrie Bodge wrote:I’ve emailed Pat Joynt at SSC asking 2 see if he can help get any of Atomic types ;-)
Good thought Norrie. Worth a try.
Postby Adam_Winstone » Thu Jun 06, 2019 2:07 pm
Knowledge wrote:I have just compared my Atomic pressure plate and the centre spider, and the five spring holes line-up very badly indeed.
... shockingly poor :(
Postby Norrie Bodge » Sun Jun 23, 2019 8:20 pm
Pat replied earlier m8
He got no old stock but gonna ask among mates to see if anyone has any?
Norrie Bodge
Postby Knowledge » Mon Jun 24, 2019 1:28 pm
Thanks Norris. It might be an idea to get a couple in if Pat makes the right contacts (I heard he was at Poland rally)
In the end I opted for the Beedspeed deep pressure plate, which arrived the next day and is fine.
Postby Norrie Bodge » Mon Jun 24, 2019 8:09 pm
Knowledge wrote:Thanks Norris. It might be an idea to get a couple in if Pat makes the right contacts (I heard he was at Poland rally)
Ye he messaged me & said just got back from Poland a few days ago m8
If he comes up trumps I will PM you bud...
Good to here the Beedspeed ones are working ;-)
So is your setup:- ATOMIC deep spider & crownwheel with 5 or 6 plates???
Norrie Bodge
Postby Knowledge » Wed Jun 26, 2019 2:44 am
It is a six plate set up.
I milled the space for the ears of the cork plates so they sat lower in the basket, and use a Surflex 5 plate clutch, plus one standard cork plate and a selection on thinner steels. The springs are MB. The centre is deep Atomic and the pressure plate has already been discussed.
It is light, using an RD lever, and worked first time with 28bhp and 28ft lbs of torque. I would like to think that if I have a problem whilst touring, I should be able to source replacement parts without too much trouble.
Postby Norrie Bodge » Wed Jun 26, 2019 7:51 pm
Knowledge wrote:It is a six plate set up.
Great info mate,
so is your crownwheel a ScootRS Type or a milled std one?
My plans the same 6 plates MB Springs & the ScootRS clutch Parts ;-)
Norrie Bodge
Postby Knowledge » Thu Jun 27, 2019 4:58 am
It was a Scoots RS one.
They were all crudely filed in the area where the friction plate tabs sit, but they should have been milled before they left Vietnam as failure to do so left them sadly shortly of their full potential.
Postby Norrie Bodge » Thu Jun 27, 2019 5:31 am
Knowledge wrote:It was a Scoots RS one.
Yes got a 47toothed one in my GP & did that one before fitting
Also got a 46 which is what I’ll use in this next build
Norrie Bodge
Users browsing this forum: nastro azzurro and 59 guests
