Shorter Shocker!
Shorter Shocker!
Postby Hughieboy » Sat May 18, 2019 1:52 pm
Hi
In the middle of fitting my new Gt186 kit with 30mm l/h carb manifold I’ve discovered the shock is now too long!
Current one is an Escorts 310mm and it looks like I need something no more than 295mm ideally.
Bit of a bugger as I hadn’t factored it in to the finances so as don’t want to go too fancy. I read somewhere that an R6 shock might fit but I’m not sure about the difference in weight and whether they are a direct fit. I don’t want to mess around too much if it can be avoided.
Any suggestions would be gratefully received please!
Hughieboy
Re: Shorter Shocker!
Postby roli150lam » Sat May 18, 2019 3:18 pm
I've got a gt kit with left hand manifold.I have a 300mm rear shock on it,nothing exotic just a standard S3 length shock.
Oh yeah offset frame cones will help too.
roli150lam
Postby Hughieboy » Sat May 18, 2019 4:07 pm
Unfortunately I have centre hole cones and they’re not that old so I don’t really want to mess about changing them again. 300’s might just fit I guess but 310’s sure don’t!
Hughieboy
Postby Knowledge » Sun May 19, 2019 1:13 pm
The R1 shock will fit and is shorter (300mm). It has an in-line reservoir.
The R6 shock comes in two styles. One with an in-line reservoir, and one with a transverse reservoir (which is only any use for cut downs).
Both need a change of spring (180 - 200lbs) from Demon Tweeks, and some replacement bushed at each eye of the shock. They also need machined-down nylon nuts top and bottom to secure the shock to the scooter.
Buy a complete unit from K2 Custom or Chiggy Chambers, and save yourself the hassle.
Postby MickYork » Sun May 19, 2019 1:33 pm
How difficult is it to strip a standard Escort shock and shorten the spring and damper rod ? if you're on a budget it might be worth a go.
Postby HxPaul » Sun May 19, 2019 6:07 pm
Postby Solid Air » Sun May 19, 2019 6:17 pm
My GT needed offset cones and some fettling of the manifold too.
Pm me you're address, think I've got a spare set in the garage you can have.
Mark
Postby Hughieboy » Sun May 19, 2019 7:11 pm
Thanks Mark!
However I came too that conclusion earlier and ordered a set along with a Scootopia adjustable shock (s3 size)
I appreciate the offer though :D
Hughieboy
Postby Solid Air » Sun May 19, 2019 7:36 pm
Wise man :D
Postby petemaisey » Tue May 21, 2019 9:22 pm
Alf Hagon Shocks made me a special damper only.
Ordered on Thursday made to order shipped and then fitted all in less than 24 hours. highly recommended.
petemaisey
Postby Hughieboy » Fri May 24, 2019 11:20 am
So...
I fitted the offset cones and 300mm adjustable shock. I now have about 5mm gap between the manifold and the frame which is all good so far. However, when I put the rubber carb boot on the manifold, this now touches the frame. Not so bad that I can’t get it on but it is in contact. Will this cause problems? Not really sure what else to do as I’ve created as much space as I can.
I’m assuming that movement would tend to be the other way but if someone could corroborate that Id be grateful before I go out and break it!
Cheers.
Hughieboy
Users browsing this forum: nastro azzurro and 57 guests
