by Jono » Sat Aug 30, 2014 10:18 pm
Anybody got any idea where I can obtain a wheel rim stud from for an Indian rim. Unforntunately I have one stripped on my SIL Gp150 ( that is the stud that holds the rim halves together) Scooter restorations are out of stock.
Jono
Jono
by Tony Hart » Sat Aug 30, 2014 10:57 pm
Jono. I got some a few weeks ago from Allstyles (The ones that need welding)
Tony
Tony Hart
by Jono » Sat Aug 30, 2014 11:57 pm
Thanks Tony
Was hoping to avoid welding if possible. However, I will have a look at Allstyles as a fall back contingency should an alternative not be identified. Jono
Jono
by Teglease » Sun Aug 31, 2014 12:31 am
Hi I got some from Gary at Allstyles, you can get away without welding them, you can edge pot them as long as you do them up tight no problem
Teglease
by HxPaul » Sun Aug 31, 2014 10:09 am
Jono wrote:Anybody got any idea where I can obtain a wheel rim stud from for an Indian rim. Unforntunately I have one stripped on my SIL Gp150 ( that is the stud that holds the rim halves together) Scooter restorations are out of stock.
Jono
Just use an ordinary bolt the same size and thread,then put a nyloc nut on and tighten with spanners.
