Hi. Would a failing pick up on an electronic ignition affect timing? Struggling to get timing down to 19 degrees after fitting new crank and flywheel. All resistances are within range. Checking timing with strobe.
Tony
AndyVee wrote:Hi Tony, did you fix this problem ? I have a similar issue after making the same swap TO crank on an SX case. Wondering if there was a bad batch of parts ?
Users browsing this forum: nastro azzurro and 58 guests
