Fast n Furious wrote:Dan
Your piston measures up ok but looking at the picture you posted I would check the integrity of the piston ring pegs as they look a bit dodgy. This is typical of what happens when rings are allowed to wear as far as yours have. If the pegs are the old brass type then I wouldn't re-use this piston. Call it a day and fit a new one.
New rings should be gapped to 0.23mm for this bore.
Warkton Tornado No.1 wrote:As Chris said, that clearance is good, but by no means tight. For the record, with a 66 mm bore, I aim for only 0.0035" (0.089 mm) so don't go mad if you do run a three leg honer down the bore to deglaze it. If you do so, remember to deburr all port edges.
Your piston should clean up nicely with some light abrasive pads ("Scotchbrite") Check that the windows in the skirt are not cracking & remove them if they are. All piston edges around the skirt can benefit from chamfering & polishing in general, particuarly so that oil on the bore face is not scraped away, as well as the inside face having more of a knife edge to function better closing the inlet port.
To get the optimum ring gap, personally I would buy oversize & regap them. It really doesn't take long with a good file, in fact it's all too easy to go too far, though I would advise good lighting & even a magnifying glass to get things right
Danbretta wrote:I've got a new piston and ring kit, bore to piston clearance is now 0.04mm. I'll check the clearance again after the bore is honed. Is 0.089mm (3.5 thou) the clearance I should have?
Danbretta wrote:The workshop manual states 0.034 to 0.046 if I'm reading it right. Although some recommendation I've just read say 0.051 to 0.064mm.
Users browsing this forum: nastro azzurro and 57 guests
